So I have a 2010 G3 16' stick steering boat with a 50 hp Yamaha that I've had over a year now. I really like the boat and since I am 66, I imagine this is the last one I will own. The only thing I have really disliked has been the 12 volt Edge trolling motor. I have to run it on 5 to move the boat at all, and when I fish current it often won't even hold my position.
So I found a 24 volt Maxxum in good shape, knowing I was gonna face a problem - the standard 5' steering cable is too short. The Maxxum will fit the holes they drilled at the factory for the Edge, but it's too short by about 6". The shaft cleared the bow by 5" when the Edge was down, and I thought that might be enough room that if I move the new motor back so that I have just 1" of clearance it might work. It's close, but still a couple of inches short. The front deck is so high that the cable has to make a sharp bend upwards to clear it. The front of foot control doesn't touch the floor the way it is now. If I didn't have the deck, I believe it would work.
Here is what it looks like:
There is a cooler under the deck lid and I have removed it. It's not a very efficient cooler, but I hate to have to do without it as there is not a lot of room on the floor.
Looks like I have 2 possibilities, but I am open to other ideas. The easiest would be to buy an 8' cable for about $100 and replace the 5' with it. I could then mount the Maxxum where the Edge was and wouldn't have to change anything else. The downside of that is that the 7' cable on the Edge is already way too long and is constantly in the way. An 8' will be even worse. Also, there is room for only 2 batteries in the back compartment, so I will have to use the same battery the cranks the outboard and powers accessories to get the 24 volts for the trolling motor. I never fish more than 6 or 7 hours, so I don't see that as too big of a deal. Still, it isn't ideal and it would be better to have 3 batteries.
The other option is to take a saw to the piece of aluminum at the front deck. I was thinking I could just cut a slot about a foot wide from the center over to where the compartment starts that has the foam in it. That compartment has a plywood cover that I temporarily removed. That would make it possible for the steering cable to lie flat on the floor and to fold upward when the motor is stowed. I could then design something to hold both of the trolling motor batteries in the area where the cooler is now. The boat currently has too much weight in the back and it porpoises at top speed if there is someone on the back seat.
I am thinking that I like the second idea best, but I would like some advice from you guys before committing to it. Once I take a saw to the aluminum, there is no going back.
Thanks for any ideas!
