1994 Johnson 50/35 on a riveted 1996 Tracker 1648. With 2 guys and fishing gear I use to get upper 20's spinning at 53-5400 rpm's. Nowadays I'm down in the lower 20's spinning 51-5200 at WOT. Compression is good and even on the motor which has 75 hours after a complete rebuild a few years ago. The hull has seen it's share of bottom dings, dents and a hole or two. I know my top end is effected by the abuse the hull bottom has taken, but what about the WOT rpm's? Will increased drag from a beat up bottom decrease WOT rpm's?
