Drivers seat ideas
idruthrbfishin
I run a 1648 modified vee with a 60/40 jet outboard. I have a center console, and I'm looking for ideas for a stand-up style drivers seat mount. I have an open floor plan, with 1/8" aluminum screwed down to the ribs. This will have to be a sturdy mount that will be taking a lot of abuse as I run rocky shallow rivers. Basically I am looking for a very sturdy way of mounting the seat to the floor/ribs. Screws will eventually work loose, and I can't really bolt it down to anything with thru-bolts. Any pics and or ideas would be appreciated.
Since the floor is screwed down you can unscrew it where the seat will mount and attach a piece of plywood under the aluminum floor. Then put the floor back down and mount a seat base / pedestal.
On our G3, the seat doubles as a livewell and is a two person seat, but not a standup. I don't remember the floor thickness, but it is certainly less than 1/8", and is screwed in place. With 1/8", I'd think that would be plenty strong for a screw attachment. Use some sealant on the screws to prevent back out.
Just thinking out loud. I'm envisioning a tubular framed seat structure with flanges that mount to the floor at four mounting points. Something like this: Leaning Post Seat Guessing 3.5-4" flanges. If you feel you need more support, go to a larger flange base. Say 6-8" diameter of 1/8". That would thru bolt to the existing flanges, and provide more screws around the perimeter with stronger support. You will need holes in the floor for the thru bolt clearance and a beveled edge on the new perimeter to minimize stubbing.
Pictures of your boat and the seat might generate more ideas.
As mentioned above, I would lift the panel in that area and install a square of 3/4" plywood from rib to rib, glued and or screwed to the bottom of the floor panel. That dampens impact, prevents flexing and gives a lot of bite for fasteners. This is what I have done in many circumstances, and it works well.
Or use a 10x10 aluminum plate 3/16" / 1/4" thick. Thats how I will be mounting my pedestals to the benches.
I was going to do that on my last one, until I saw the price tag on the aluminum. YIKES!!!!
I have a few pieces of 1/8" aluminum I will cut down to 10"x10". The pedestals I want are the Wise fixed 6" tall drivers rated for driver and passenger.
If the OP is trying to use a tall, 30", pedestal seat, that will be a problem. Plywood or aluminum. The length of the pedestal is a long lever. The front screws are going to try to pull out on every acceleration. With a jet, you are doing that all the time, to get shallow as quick as possible. I have only seen these tubular framed seats in this type of application. They are expensive, so there is probably a good reason why.
Otherwise, plywood support does work, and have used it myself with no issues. Getting the floor up may have its challenges, and location of floor supports is unknown.
In my experience, I have found wood to be the best support as it has some give/ flex where the aluminum was more rigid. Also use a bigger base when using a tall seat as the extra leverage can easily rip the fasteners out of the ribs. On mine , I made pieces that attached to the ribs themselves to spread out the load and pull of the seat stand. My bases were 16" square and had no issues. The brackets I made attached to the ribs thru the side, not from the top of the rib, so far less likely to pull away with extreme use.
