- Joined
- Feb 18, 2009
- Messages
- 2,536
- Reaction score
- 2,471
- Location
- Perrysburg Ohio
- LOCATION
- Perrysburg Ohio
Until they have a problem ! Service after the sale when a problem arises is what makes a purchase a good one or a bad one !
Amped treated me well by replacing my battery with the wonky BMS with their newest version with bluetooth. Happy with that. But the sub-handful of people I've encountered that have had issues with TimeUSB have gotten their batteries replaced as well, so that seems to be a wash. I see some mfgs say they have 10yr or more warranty, but with the way technology moves these days and companies come and go, are they even going to be around? If I can buy 4 batteries for the price of 1 and they have a 50% failure rate I'm still better off with the cheapies. And while my cheapo has had no problems I've had 2 USA "name brand" batteries need replacement.Until they have a problem ! Service after the sale when a problem arises is what makes a purchase a good one or a bad one !
Hello Richard
Thanks for your message to Timeusb. This is Mona here to help you
It is not recommended to place your battery with the back and top facing downwards. All other directions are acceptable.I have marked the front and top for your referecne, and the oppsite side of the ”front“ is the "back "
Could you tell me how you plan to use the battery and what device you'll be using it with? I want to check if it's a good fit for you.
Looking forward to your reply![]()
Best regards
Read up carefully before purchase.....a regular charger will not work unless it specifies a " lifepo4 " type battery !! Using the wrong charger can cause a serious fire. These are great if properly handled and maintained. If you not willing to get seriously educated on these type batteries, then stick with normal lead acid type batteries. If you typically run your trolling battery below 50% each time on the water, then the extra capacity of the lifepo4 battery will be worth it, but if you only use a small portion of your current trolling battery, then the cost is probably not worth it.know nothing about these but they sound great. just need a trolling motor battery. will they charge with my old minn kota charger or do i have to buy a different one also. wondering if its worth it for my usage or not. 50lb. thrust on light 1436 jon boat, trolling here and there, not the only motor.
