Electeic feather build
DOCEDA said:
Glass flat bottom pirogue
[attachment=-1]uploadfromtaptalk1397449828331.jpg[/attachment][attachment=-1]uploadfromtaptalk1397449847142.jpg[/attachment][attachment=-1]uploadfromtaptalk1397449874953.jpg[/attachment][attachment=-1]uploadfromtaptalk1397449891948.jpg[/attachment]
    63.1 KB
    76.5 KB
    60.9 KB
    69.7 KB
Paid 125.00 for the boat and drop 225.00 into it. Happy with the outcome but I have one issue, the inner hull floor has water below it and I want it out anyone know how to take it out?
So you have water inside the boat?
My first concern is where is it getting in? I've seen those sometimes have a drain plug. If it doesn't, could you add one? That would allow you to get the water out and in the future.
I added a drain plug but it's not going through both the inner and outer shells. The floor is the only place where I can feel a separation of the two. I also think the water is coming in through the mounting holes for the motor cage. This will be where I start first by removing the cage and tilting the boat nose up and seeing if any water comes out the the mounting holes.
