RivRunR
I agree with all of the above...that amp rating seems too low, but if it is correct it would take a 50A breaker. And I agree with JMichael that mfg's don't install breakers for a reason, but maybe that's because the length of run is so short, and maybe they over-size the wire to compensate???
You're probably going to need a pretty heavy wire, like maybe 4AWG, to avoid voltage drop, so I'd think the likelihood of fire with wire that size would be slim...especially since the amp spike will only last for like a second, if that. On the other hand, there's no real downside to putting a breaker in the mix, other than the aggravation of figuring out what size, and maybe the price.
Best bet is probably to find an ammeter somewhere and measure the actual spike yourself, then go from there.
