bdbarrie said:Anybody in Ontario Canada Order this stuff? I want to order but wondering if they will ship it over the border, i know gluvit is unavailable up here now.if so how much will it cost me? and does it come in Grey?
Thanks
Bill
hallzyballzy said:Does anybody know the shelf life on steelflex? I ordered a gallon of black for my 14' jon boat. But it looks like I'm going to hold off on decking it out. Might be buying a house in the next month or so if everything goes good. Any ideas?
downtofish said:I was wondering the cure time on steel flex, Could I get away with painting in a heated garage ? or does it take a few days to cure? I wouldn't want to run heaters more then 2 days straight but 24 hours at a time between coats would work... if I have to wait till spring I will but I'd like to have this thing in the water by april and counting on weather in NJ is like playing russian roulette. I havn't called fasco yet, figured somebody on here could help me out. Thanx in advance!
125temple said:I'm doing a 14' Jon boat project, and the person before be let barnicals eat away at the bottom of the hull, Can I spray steelflex on the bottom to strengthen it? If you take a screw driver and stab the bottom you can puncher it, but not the sides.
I was thinking bedliner might work...
Galveston340 said:125temple said:I'm doing a 14' Jon boat project, and the person before be let barnicals eat away at the bottom of the hull, Can I spray steelflex on the bottom to strengthen it? If you take a screw driver and stab the bottom you can puncher it, but not the sides.
....SAY WHAT? Personally if the hull is in that shape I wouldn't consider it sea worthy under any circumstances no matter what you coated the bottom with!!
mdue151 said:I have a 12 foot riveted v hull...what steel flex would I need and how much?
groundshock said:How does this stuff hold up to scratches/scrapes/running aground? I launch out of a couple rivers that have no docks, and you have to beach it to land.
Was thinking that paint may not be the best idea in this situation.
Dockside85 said:One more Steelflex question for any one that knows. I ordered it and I have 1 gallon in the two half gallon containers and the pigment. To save a step in the mixing process, can you simply add all the pigment into the neutral base beforehand so you only have to mix the neutral base and the clear hardener? Or would that throw off the 1:1 mixing ratio?
