LDUBS
- Joined
- Aug 14, 2016
- Messages
- 6,746
- Reaction score
- 3,638
- Location
- Northern California
- LOCATION
Thank you Sir!You have done some excellent work on that trailer, but it seems awfully high to me.
I would try it out before finalizing anything. If the ramps you normally use are pretty deep then you may get by with it, but on shallower ones you may be dunking the tow vehicle to float the boat off.
Nothing readily availiable over the counter....custom sizes are made every day, look for a local fab shop or building steel products company and call them with your dimensions. Sure it will cost a few extra bucks but far less than a new trailer. You really don't need a total square, a fab shop can make a U shape that slides over or inside once they know the weight your dealing with.The issue I have been having is I cannot find a tongue extension that would slip over or in. Everything I have found is 3 x 3 x .120. Nothing bigger or smaller.
Thank you @thill!When I have a light boat like that, I drop the tire pressure down to help absorb some of the shock, around 32 lbs or so.
Those tires won't squat or feel that setup, even with 20# of air in them. The pair is rated for 3,200 lbs, and you probably have 700 lbs on them. They are overkill, but good insurance. They will dry rot long before you wear them out. Nice choice!
I did. Trust me, I did. lolHoly crap those tires seem way over-priced to me. You should have maybe shopped around a little bit more.
Check the tire manufacture's web site, many trailer rire makers have charts on how much air is required for xx lbs of weight being carried. Safer bet to be sure...Thank you @thill!
Exactly my thought when I got them...overkill=insurance. I don't want to be the poor guy on the side of a highway swapping wheels. lol
In the interim, I did a wee bit of searchin and found this website
https://tirepressure.org/
I reckon Im going to start at 50 psi and go down from there.
