MrGiggles
I'd say your bunk placement is pretty good. Further apart doesn't hurt as it helps keep the boat from rocking, but you are limited there by the width of the trailer.
Before you paint, make sure you've got some kind of eyelet set up for your rear straps.
I would also suggest adding a couple keel rollers. They don't need to (and shouldn't) support the boat, but when you're loading on a steep ramp they will keep the bow from slamming into the trailer, and keep everything centered. I think one tapered roller about halfway up, and one at the very back would be fine.
Some side bunks wouldn't hurt as well, a lot of guys like the tall guide poles, but I've found a couple of short 2x4 bunks to be sufficient. Just need to be careful and not back in too far so that the boat can float over the top of them. Keeping that boat floating over the trailer in even a slight crosswind or current is not going to be easy.
As long as the bunks are far enough apart to not hit an outboard (and yours look to be fine) you're good.
It's the little things like this that make all difference in how easy it is to load/unload. A poorly setup trailer can be a nightmare.
Lastly, I think every boat should have a safety chain for the winch. So while you've got the drill bits out...
