ben2go
#-o #-o #-o I wanna say bad words at this point.I went out this morning to start the modifications to my boat.I think it's a 1032 Gamefisher.The previous owner was Merrietta Camp.The kids did the up keep and mods.They removed the flotation foam out of the 2 seats and bolted in 1 piece fiberglass swivel seats. #-o #-o #-o I can't get the old fiberglass seats out because the bolts are rusted in so bad.The heads are rounded badly and I can't get anything on them to break them.I had already planned to to install new structural supports and wood decks with fold down swivel seats.My problem is all the rivet holes that will be left after I remove the original aluminum bench seats.What would be the best way to seal them?I wanna use Alumiweld rods and a hand held torch.The problem here is the thinness of the aluminum hull.It's as thin or thinner that aluminum siding.I don't wanna warp the metal and cause it to be wavy.There is entirely to many holes for the screw and nut idea.When I replace the transom wood,I'll have to fill holes in it also.At this point I am open to all ideas.I would just stitch weld it but it's way to thin. ](*,) ](*,) ](*,) Oh, the reason I decided to go ahead and remove the bench seats, is because they are weak, have bowed down and cracked.There was no bracing underneath for the swivel seats.
