slross83 said:
Well i bought a 1860 grizzly sportsman with 7 50w led seelites. port has 2, star has 2, and bow has 3. Three separate switches. All factory wiring. The problem im having is if i turn all switches on after a couple minutes all the lights will turn off and on repeatedly until i turn off one switch. Now if i turn off the bow the sides will stay good and run fine. But if i leave on the bow and one side which is 5 lights total then a few minutes later the same thing will happen. Bottom line 4 lights im fine but when that 5th turns on it goes off and on. I'm no electrician but they are ran to 2 12v batteries in parallel. This whole system is 12v. Previous owner said he didn't have the issue. I spoke to his mechanic and he said the wire size wouldn't be the problem because it ran fine for 5 years that way. So any ideas would be much appreciated. Weak failing fuse? undersized fuse somewhere? Bad batteries? Idk. Thanks for your help
This info is based on little knowledge of how you boat is actually wired, but should help.
Undersized fuse would blow, oversized fuse would not provide over current protection. Probably not a fuse.
2 12 Vdc batteries in parallel, not likely battery issue. These leds list there actual watts, not estimate. So you are using approximately 32.2 amps with all 7 leds on. To illuminate the batteries, with a volt meter connected to battery, the volts should stay around 12.6vdc (charged batteries) with the lights on/flashing and also when the lights are off.
Since 3 separate switches, a common failure causes all to shut down. Most likely a corroded terminal, bad splice, or loose connection.
If the lights are on the same fuse, (probably 30a or larger & switches wired in Parallel) check the main wires between fuse panel and switches for corrosion, and good connection.
If you have bladed fuses, pull them and check for corrosion, if cartridge - remove and inspect for corrosion, if circuit breakers - reset them or check with multi meter.
If each light has separate fuses, chances of 3 bad circuits is slim, more likely the return side has bad connection. Check the (-) or return side of the lights for corrosion, and good connection., they probably tie together at a bus bar in one location.
Not likely power connection between battery and fuse panel, you would have other issues with voltage
