wheelie
took the boat out yesterday , launched it , started up the 1985 Evinrude 40 , ran real good at idle , water pump peeing real good …. idled out thru idle zone , just as we got to open water , we got the alarm squeal…… constant, loud , squeal , water pump appeared to be doing fine…. NO VRO on this one that I can see and no oil tank . weren't sure if it was a overheat squeal or not so I put it wide open for a second to see what it would do and it wouldn't go any faster . It had shut itself down to about 2000 rpms as it should do for safety purposes not to ruin motor ...… the head felt hot , the entire engine felt hot , so we idled it back to shore and loaded up ….although it was still peeing good , I wasn't sure the entire engine was getting circulation….
took it home , pulled the lower unit , water pump looks great , pulled the head cover , thermostat isn't stuck , and bypass valve isn't stuck either , shot water up thru the lower tube, it came out the pee hose , then out through the thermostat hole, so all clear there , then poured water back through the head and it came out the bottom , through the vent holes and exhaust so all clear there …..
so now I'm wondering why it got hot and shut down …… maybe its lean ? I'm not sure whats going on …… Its mixed at 50-1 on the oil gas mix as well…….. another question is , do the gas tanks have to be vented ?? I can remember as a kid going out with dad and several times in boats and we would take off and run so far and the boats would shut down , and he would open the gas tank lid vent , and away we would go ….. this tank doesn't have a vent , nor does the new plastic one we just bought … should they ?? any more ideas ??
I also have a fuel filter inline between the tank and primer bulb that is brand new , and I removed the cover off of the fuel pump and the screen is clean..
