Got her out today, splash between transom and pods is significant, so I'll have to do something about that. Seems to cost about 1-2mph.
They do float the boat, however. Here I have 2 5 gallon buckets on the pods, 1 bucket in the boat, and 20 gallons of water dumped in the boat.
Here is the same and I have flooded the pods. Pulled the plugs and tipped em up till the bubbles quit.
Here is a shot, I am standing on the pods, not flooded, with 3 buckets of water in the boat. Water is just covering top of pods.
Still a bit of freeboard left, considering such an extreme. 225 pounds on the pods, and 120 pounds of water on the seat.
Tried to get shots of all the different lods with a tape measure in the image to show how much freeboard was left, but didnt want to go swimming....
Act as a semi decent brake while pods are buried and main motor is at an idle, or as close as I can get it and keep running. Drags down to 1.5mph.
Keeps the stern up pretty high, thinking this will be nice for trolling.
Pretty excited to strap a 15hp on her, if I could set it back 6", I would clear the pods in any position. Cavitation plate does touch when they're buried, makes a hell of a racket. (Not the prop, checked that earlier!)
Current motor sits 2" or so too low so 6" back and several up should help a good bit.
Here's a before pic, just motor no added weight.
