Can someone point me in the right direction on what to do with the wood under the side panels? The floor is in decent shape but I am adding a battery up front, replacing the deck in the nose of the boat, and adding a bench across the back for me and to add storage. Figured mise well try to replace the main floor while I'm at it. But I hit a wall when I saw that the plywood ran under the side panels. I've replaced a few boat floors with my pops but they were tear out the rotted and put the new pieces in, not like this. I thought about cutting it at the edge and just leaving the wood under the livewell and side panels. But not sure the best way to go about that even.
