Battery for Bow mount trolling motor
davidj65
TinBoats Supporter
Owego, NY
I currently have a basic 55lb MinnKota in the stern that I use for shallow water and edges, just nosing around coves and such. Runs all day with that level of use on a group 31 Interstate 12V lead acid battery, which also powers the house stuff (lights and sonar and 12V phone charging ports). No spot lock, I use an anchor.
I'm planning on upgrading to a bow mount Terrova and use the spot lock instead of the anchor. The troller will obviously will be running a lot more than it currently does. So I am wondering, what can I expect for battery life? Do I need a couple batteries to get through a long day of messing around?
I like the idea of the LifePo batteries but don't know much about them. The lead acids have been fine for me in my very limited experience, but I'm not tied to them. Ditching some weight would be good. Can the lights and sonar also be run off a Lifepo?
I know some people say not to run sonar off the same battery as a troller, but so far I haven't had any issues with that.
I have a 55# MK with spot lock on my 16' Sylvan side console. It runs on two dedicated group 31 lead acid batteries. It can last for up to 8 hrs depending on how hard it is used. When these 6 yr old batteries give up, I will replace them with a single 140 ahm LifeP04 battery and expect to get similar or longer run times. I also have a dedicated start battery for the motor and a group 29 deep cycle for all accessories as a house battery. LifeP04 are great...but MUST be handled correctly with storage and handling.
I highly suspect that your current G31 will be fine. Try that first and check the voltage level before you put the charger on, at the end of the day. If you find it is deeply discharged, then that would indicate you want a large capacity LiFePO4. My guess is that your stearn trolling motor is fixed speed selectable, which are not as efficient as your new Terrova. So you gain a little there.
If you use or plan to go with one of the newer "Live" or forward scanning sonars, they tend to be power hungry. That could drive you to two batteries.
You didn't mention it, but if your battery is connected to the motor, it will take a special LiFePO4 that can handle the charging from it. As Airshot mentioned, there are some extra precautions using LifePO4, too.
I have a 55# Minn Kota Powerdrive on the bow of my tinnie. It is outfitted with a ProNav controller so the TM setup has all the navigation and wireless control features. I use a Group 31 size 100Ah LiFePO4 battery mounted in the center bench to power the TM, along with my H'bird Helix 7. I don't know how long the battery will power that whole setup; I've never been able to run it out of juice. When I fish the small and medium size lakes that I have nearby, I typically only use the outboard for the first run in the morning, and the recovery at the end of the day. All of the rest of the time is spent on the TM.
I crank the outboard with a separate small Group 24 lead acid.
The LiFePO4 weighs 26 pounds. The much smaller LA battery weighs nearly 40. I know a Group 29 LA battery will be pushing 70 pounds or more.
Like others, I would try the battery in hand before deciding to buy another battery. However, if I'm buying a battery for the new TM, I'd go with a LiFePO4, no questions asked. The cost of a LiFePO4 is approaching the cost of lead acid, and it's superior technology and longevity. I think the Terrova is 24V; my suggestion applies for that situation as well.
I have a pair of 100 AH TimeUSB LiFeP04 batteries for my various TM setups.
On my last trip out, I connected my Time USB 50AH battery to my M. Kota 55# Terrova because I had it around. I thought I'd swap batteries after awhile, but that battery ran all day long, mostly for spot lock, but with a few decent runs thrown in. I was impressed!
It's temptimg to use the 50AH more if it performs like that. It's much, much smaller, and seems to run the MK exactly the same as the bigger ones. It's at least as strong as my Group 29DC lead battery, which is impressive
I’ve had great luck with Les Schwab deep cycle batteries. The first pair lasted me around 12 years.
thanks, that's my general feeling, try the current GR31 and see how it goes. I've had great luck with interstate batteries in general. The current one is a new dual use that I bought with the motor two years ago, but my boat came with a 2017 Interstate gr31 dual-use that the previous owner had used for the troller, and it still holds a charge just fine. I have a separate dedicated wallyworld starting battery, so the troller is running the minnkota and the sonar.
LA will last a long time when they are maintained well. Charge them right after each use, goes a long way. I went to LIFePO4 on the jet boat to reduce the weight and the much longer lifetime. Now, they like to be charged the day before you go. As long as they are not too low at the end of the day, just wait for next trip. Mine do not have the internal heating pads, so also can't charge when at freezing or below.
I run a 100AH Li with my terrova on a 14'. I've never run it down below 70% in a day of fishing 6-8hrs--mostly trolling at up to 2mph and spot lock but also with runs at full power. Unless you need to go days between charges or literally fish ALL day, it'll do you fine and the weight savings is great. But also no reason to buy new if the current LA is holding up.
If you do a search I posted a table a while back of current draw and speeds with the Terrova at every motor setting, if you think that info would be helpful.
If it were me.......Your gonna need more battery when you start using your spotlock. You will fund you will use the trolling motor more often so that equals more battery. I would consider a 140ah LifePo4 battery for the trolling motor and use your current LA battery to run everything else. My current wally world batteries are from 2019 and I will be replacing them this spring with a 140 ah Lifepo4 battery, not wanting to get caught with dead batteries on the big lake. If at all possible, use a separate battery for house use ( lights, radio, FF etc) . if your motor is electric start, consider another battery for engine starting only.
This is how I set up my boats, never have to row, if a battery goes dead.
that's kind of what I figure, it would probably challenge a single battery by the end of a long day, especially with some wind.
the way it is set up now is
--1.5 year old interstate deep cycle 87ah powering the house stuff and the rear mount troller.
--new Walmart dedicated starter battery, only for the motor and bilge
I bought the newer interstate when I bought the boat in 2023, and as it happened, the boat already had an identical 2017 interstate deep cycle in it. I have tested it out and it holds a charge fine. So I thought about just running these two in parallel, or just swapping them if one runs low. See how it works out, and go from there. I've heard that if you want to run batteries parallel, they should be identical and the same age?
I
You could add a switch to swap between tbose batteries, so they don't need to be identical.
I added a switch to my 16' Spectrum. Never need it, but nice to have just in case.
I have never run down a 100AH TimeUSB LiFeP04 battery down in a single day, no matter how much I run my Terrova 55 on my deep-V, 16 footer:Resized_20231008_110826.jpeg
I have also never run the pair of 100AH down in a single day with my 24V PD with spot lock. That being said, in the Chesapeake Bay on my 22' Offshore bay boat, I have run them down to about 40% on a long day in fast currents. Very impressive! On the trailer, it weighs 4,300 lbs, so it's around 3,500 lbs in the water, plus gear.
Here, you can see the MK on the bow, mounted on a custom plate I made so I didn't have to remove the bow rail:
By comparison, I HAVE run down two new Group 29 lead acid batteries in a single day on the bay when the current was ripping. It just goes slower and slower as the day goes on, until I stop using it for fear of discharging it too much.
If you can afford $199, buy 1 or 2 TimeUSB batteries. Well worth the cost!
HEY.... Time USB just dropped their LiFeP04 prices and added new models.
Right now, a 100AH battery is $169 on Amazon when you click the instant coupon:
https://www.amazon.com/Timeusb-LiFePO4-Lifetime-Off-grid-Applications/dp/B0BBZL5BPR
The 50AH version is only $89, when you click the instant coupon. Aw man, I wish I had waited!
https://www.amazon.com/Timeusb-LiFePO4-Battery-Perfect-Lithium/dp/B0BHHQTQRT
And they now have 140AH batteries with bluetooth monitoring BMS systems for $269 with free shipping. Really good stuff. Again, I wish I had waited to buy mine:
https://www.amazon.com/Bluetooth-Timeusb-Low-Temp-Protection-Trolling/dp/B0DHCF19PB/
These are premium batteries with outstanding customer service, even if you just want to call and ask a question. I knew they would get big fast, with this kind of quality and service.
TimeUSB isn't the only brand out there. Hopefully, you got a good deal, and it will work great for you for many years.
Definitely report on how it does for others to learn from.
Well the 100ah Grp 31 LifeP04 with Bluetooth came in this is the 2nd purchase ; I'm impressed with the on screen data. I also purchased the same without bluetooth ($152); considering running the bluetooth's in parallel or dual battery switch. couldn't test do to rain today.
That sounds pretty interesting. Please post your experience and maybe a link, if you like them.
My AGM SLAs were getting weak last summer, so I bought a couple of Lifeline Fiunie 100a LifeP04 batteries (with Bluetooth) when they were $157 w/free shipping.
My NOCO 2x5 charger works well with them, and they have been great.
The AGMs, when new, were good for one long day, but with noticeable voltage drop toward the end of the day.
I have a 16' Sea Nymph Panfish stick steer with an ancient (not brushless) MK 70 Foot Pound Riptide Power Drive, and a Helix 5 Chirp G2 powered off of one of the Fiunies (as are the Nav Lights, which I seldom use). I've not noticed much difference in drain between the batteries.
When fishing, I use the MK at a .5 to 1 speed, usually either on autopilot or spot lock. On windy days, with 350# of people on board, I use cruise control and autopilot, and the MK works a lot harder .... cruise control because the motor speed and be needed to vary from .5 to 3 to keep the boat moving a .5-1 mph into the wind.... so constantly fiddling with the speed, while correcting the autopilot's wide swings.
The Fiunies have never struggled nor shown much discharge. I think they could run 2-3 days w/o a charge...and, I lost 80# in the stern.
For the slight premium over the cost of new AGMs, the decision to buy the Fiunies, in my opinion and experience, was very sound. I'm 77, and I may never need to replace those LifeP04s. :)
    145.6 KB
