97Aero
Hit one of those **** submerged rocks last saturday. Busted up the drain outlet for the live well at the transom. Noticed the boat was taking on water when I had it out yesterday. At home I filled the boat up and I have a leak around this drain. It buckled the drain tube inside the boat up and **** near pinched it off outside the transom. Any ideas of the best way to fix this? I have been able to open up the drain from the outside a bit. I think the leak is around where they weld the transom to the tube. I am not too worried about the drain function as theres two for the live well. Any worries with applying a liberal amount of 5200 around the drain pipe on the inside corner?
TIA
TIA
