yes, "popular opinion" is to avoid large areas of pressure treated materials
from having full contact with bare aluminum.
In MY opinion, blocking and bracing and the support structure can be a mix-match
of other woods or aluminum angles riveted or bolted to the hull.
Then, you can use pressure treated plywood for your decking. Although you "may" have
a problem with the adhesion of primers, paints and glue prior to putting down your carpet.
Just never-ever-never use it for stringers in the bilge or sandwiched to the transom.
Again, that is just my own personal opinion.
Good Luck
Rich, my father-in-law had a really nice older fiberglass boat that he picked up for a song
way back when . . . because the stringers under the bow were broken. When he asked me
to look at it, I saw that the manufacturer used a 2" cardboard roll and fiberglassed over it
to make the reinforcements for the bow deck. Some "big guy" broke it.... LOL and the P/O
tried to fix it with gluing sticks around it .....
We wound up cutting the entire bow out completely for more fishing room.
Now, with a LOT more experience under my keel, we could have cut out the factory messed up stuff
and encapsulated some 2" square aluminum tubing in fiberglass and it would still be rock hard steady today,
30 years later.
we learn as we grow.
My motto is this - - - - Learn One / Do One / Teach One (or three).
