seasprite
I started my restoration of my Sea Sprite1850 Jon boat with a 50 horse jet. Of coarse there's more wrong with it than planned. I plan on moving the batteries towards the bow. As a typical Jon boat the keel curves up towards to bow, so the front 38 inches(floor)are not flat. I plan on decking it and putting the batteries under the decking using hatches for access. My question is should I put the batteries in the middle (side by side) or one on port and starboard? Or is isn't there any difference.
Even with the keel at 50 inches at the stern, where the bottom curves up, its at 48 inches, If i stand on the forward deck at the bow it is a touch unstable. Nothing that would capsize it. Is that normal for a Jon? Would adding the battery weight (no weight up front) make it more stable? All the weight, batteries, gas tank,engine are in the rear. As always thanks for you input.
