ober51
After I installed the new batteries in my boat, I went ahead to tackle the non-working bilge pump and aerator switches. I pulled out the fuse panel and quickly noticed that there were two missing fuses. I ran and got a fuse I had laying around and started playing around.
In short, I could use some help with the size of the fuses I need for my electrical panel since I checked my boat manual and it said nothing but to use the right size. Why are some upside down and missing? Should they all be different sizes? The top right 25 amp was put in by me just to test to see if the aerator worked, and it does. I put that also in the missing two spots you see in the picture but the bilge pump did not work. I am hopeful it is because the fuse size is wrong and not because I need to rework the bilge pump circuit and/or get another bilge pump.
Any suggestions? What is the size needed - generally - for this type of panel? Thanks!
Edit to add: It looks like the Rule bilge pumps draw like 1.5-3 amps. I think the type I have draw 2.5, so I would put in a 3, correct? A size just above the amp draw? I guess the problem is figuring out which fuse spot is which. What accessory could require a 20 amp fuse? The top left is the vhf/cd player and that's 5, apparently.
