gamefisher 7.5
cetaws6
I bought a 7.5 gamefisher and rebuilt the carb, put a new plug in it and put a water pump impeller on it, my question is i hooked the water hose up to it and started it but where should i see water spraying out? only place i see it coming out is with the exhaust is that normal or should i see it coming out the two little holes higher up the prop.?
so theres no water supposed to come out of those two little holes that are in line with the bungee cord?
I have same motor, I just put new impeller on mine as well and I get a mist of water coming out of those two holes along with exhaust
how much water do you put in your bucket i might have to raise the water level, i get alot of air but can't seem to get any water?
Put more water in the bucket and she sprays a mist of water out the holes, that makes me feel better. Now i got to figure out why it bogs down when i put it in gear.
