Grumman Freighter canoe
Yes it’s a short shaft
And I have 4 props for it .
8/9/10/11 pitch
1985 Seahorse 15 HP love this motor especially going back up stream with a moose and load.
Thanks for the photos! A buddy gave me a steal of a deal on a 19' grumman freighter and I plan to set it up for hunting in Idaho and Montana. Not sure what motor size ill go with yet. How often do you swap the prop pitch?
I used to have a 17'4" Old town Square stern.. ( Poly not tin) . Loved that boat. Miss it regularly. It would do 23MPH (loaded with 600# of gear and people) with a 5 hp Tohatsu 2 stroke. Let me tell you 23 MPH in a cano is scary!
Not very often but I always carry spare prop when hunting. I mainly got 3 props 8/9/10 the 10 pitch work satisfactory and was stock the 8 has noticeably more pulling power and slightly higher RPM the 9 pitch has the best of both the 10 and 8 so that’s what I run the most with a moose camp load on the river. I have a manual lift and an extra 9.9 Mercury but my 1985 - 15 HP Johnson is my sweetheart .
I suggest to you 8HP Yamaha 2 Stoke short Shaft only 58 pounds
Smart move. Any boat that runs in shallow water should carry a spare prop IMHO. In this case, a 19' freighter would be a heck of a paddle back to the put in site ! :oops:
Their is no paddling the rivers are 2 swift you can drift down easy and fast and sometimes get in trouble if not under power but going back up a good 8Hp to 15 Hp is needed. You can’t paddle up the Wood River or Tanana River
How hard is it to lower that lift while running? I assume the spring system keeps it up for the most part. Also does your lift attach above the Gunnel or under?
Maybe this will help you !
I have a chain with links on handle but I just tied small rope loops and just loop around the handle for certain depts of river. Mostly I run at one setting and forget about the Lyft. Very nice to have. And if I get into real shallow water just tie it off at the highest level and save your arm strength. I have the spring adjusters set for the 15HP at the halfway mark, so I got room up and down !
    33.5 KB
    29.2 KB
    28.9 KB
    98.2 KB
8HP Yamaha 2 Stroke only 58 pounds most excellent. Changing Prop Pitch not very often I mainly run 9 pitch on 15 HP Johnson for everything hunting. But I always take a Jesus Nut and extra prop 8/10 pitch with pins with me hunting.
Speed is not my friend, slow and careful in swift Alaska waters. It could be very lethal here if you go in.
