Wallijig
I just got a Maxxum 24volt trolling motor. It's mounted on my boat permanently, my tarp is custom made so I do not have to take it off in order to tarp it.
Does one need plug to hookup power? I plan on hooking it up direct. I look as a connection as one more weak point that could go bad or cause resistance reducing performance. I have a breaker by battery connections that I could open for long travel and long term storage. I use boat 3-5 times a week and is plugged into on board charger when ever at home so do not see any issues if it does draw small amount of power when not in use. As for charger damaging it, how would on board charger be different then alternator from outboard motor charging batteries outputting 14volts? With isolator is being used so batteries are being charged independent & not drawing current from each other.
Maybe I am missing something? What's your thoughts?
