flintcreek
Sader762,
Put on the new head gasket and if you had 47 lbs. with a blown head gasket leaking into the other cylinder, it is going to jump and you will have 100 lbs. or more. I believe it will be ready to go. I have seen it before where you can spin the flywheel with one finger and knew it had no compression and go over 100 lbs when a new head gasket was installed. Just check your mating surfaces to make sure they are flat with a good straight edge. If you have to on the head you could use some wet sandpaper and a piece of glass to polish it flat. I believe it is fixing to run...just make sure your water pump is pumping plenty of water...Flintcreek
