authentic
Russ, What size are the posts on those battery terminals(1/4, 3/8?), for attaching the accessories? Just curious what size ring terminals I should be getting.
Also, what size heat shrink wrap do I need for 6ga battery cables? I'm going to have that place put the battery terminals on for me.
For connecting my trolling motor, the positive cable from the motor and from the battery will be connected directly through the breaker, correct? So, no need for ends on that side of the cables. Then, on the negative side, I can connect the two cables with that single post busbar using 3/8 lugs, correct?
