I'm hoping that someone can give me some guidance with this problem I'm having with a 60's Johnson 6hp.
I think that the motor is not getting any gas. If I spray some carb cleaner into the carb, it will fire right up. Unfortunately, it will not keep running more than a few seconds. If I don't spray the carb cleaner, it won't start at all.
I have rebuilt the carb, replacing the float, seals, etc. The fuel pump is new, as are the lines going in and out. The points are new and I had them properly set. The fingers on my right hand are black & blue from my numerous failed attempts at starting the motor.
I've tried starting it while squeezing the bulb, but this makes no difference. I have also tried screaming obscenities at the motor, but this has not worked either.
The gas is a little old, I'm going to get some fresh to make sure it's not the problem, but I'm pretty sure that it's not.
If anyone has any suggestions, I would greatly appreciate it!
