Bantou
- Joined
- Sep 4, 2024
- Messages
- 169
- Reaction score
- 145
- LOCATION
- Central Texas
While getting all of the trailer lights rigged up this weekend, I noticed some things with the trailer that concern me. The middle roller doesn’t fit the bottom of the boat well, putting all of the pressure on the center rib. I think it is also a little tall because there is visible space between the bottom of the boat and the runners for about the first foot or so.
Are these things ok, or a “down the road” fix, or a “fix it yesterday” issue?
There are also some issues with the winch/winch support that I’m probably going to have to address. The trailing arm is too tall and hits the eye hook on the boat while loading/unloading while also not preventing the boat from running all the way up to the winch.
I’m not sure if I should move it down and try to adjust the angle so the boat goes over the winch, or just move it down and add a flat bump stop like you would find on a pontoon.
Many thanks for the help,
Bantou
Edit to add: I know the bunks need new carpet at a minimum and probably just need to be replaced outright. The plan is to do that once I have the boat put back together and can leave it floating on my folks' pond for a couple of days.
Bantou
