Hitch extender
New River Rat
New River in Virginia
Has anyone used on of these before? What are your thoughts?
I looked at these for my setup, but decided to extend the tongue of my trailer instead. The reason I did this is I've read that the hitch extender will reduce the tongue weight limit of your hitch by 1/3.
Description
The Receiver Extension with Diamond Tread Step is ideal for slide-out campers with extended overhangs. Step surface area measures 6" x 17" and is welded to hitch extension.
•The limiting factor is the capacity of your hitch. Using a hitch extender will reduce your hitch's overall capacity by 1/3.
https://www.reese-hitches.com/products/,1804017
I ran one of those on 2 or 3 trips. I know this won't be much help, but it just didn't "feel right" when I was towing, so I took it off. Only thing I use it for now is to give me more room at the lift-gate when I've got the cargo basket in the back.
I have one sitting in the garage, I used at a boat ramp I had to make a sharp turn, it did keep the boat from hitting the truck
