RiverBottomOutdoors
Thanks for the tip on the Anderson plugs. I will definitely look into them.
hipster dufus said:went out yesterday, w new plug. worked great. only issue is the 90 deg bend sticking up. will try inline adapter and see how it works on next trip.gotta say though, i hate my tm. 55# minn kota. always tightening screws . now the cable sheath popped out of the head. anyone ever deal with that?
Catch Release Repeat said:Well you guys talked me into it. I went for it. No report yet, hopefully I get out soon to give you guys a review. Install was a breeze. I used 10gauge flexible silicone wire going to the battery which was tinned copper and seems to be top notch, extremely flexible. The connection also has caps to cover the terminals from the elements that you can see in the second pic.
mbweimar said:Catch Release Repeat said:Well you guys talked me into it. I went for it. No report yet, hopefully I get out soon to give you guys a review. Install was a breeze. I used 10gauge flexible silicone wire going to the battery which was tinned copper and seems to be top notch, extremely flexible. The connection also has caps to cover the terminals from the elements that you can see in the second pic.
Where did you get the meshy wire loom? I like that stuff, but can't find any locally.
skipper123 said:Now your talking, that flat plug is what I use never even warms up. I melted all the plugs made for trolling motors as well as the big foot switches two a year. And yea I know wire sizing and over size everything. If you want to see what she will do troll upstream in the Savanna river current dragging large striper lures for about six hours on high speed with a 12 volt 55lb motor. That will give the electrical system for the trolly motor a serious test. The weak link will fail or melt. Mine was the plug and big foot switch every time. #6 copper wire straight off the battery with electrical lugs would carry the load and not heat up but the plug could not handle it. Finally took out the plug and switch and straight wired it with the 60 amp cir cute breaker at the battery. Problem solved never had trouble after that.
eshaw said:Did the caps come with the connector or can you get them seperate?
