Capt1972
I know this probably is not the correct thread for this but I wanted as many of you to see this as possible.
Tried this tonight after work and it works slicker than sh**. If you have access to a pressure washer, put a 0*(straight stream) tip on it and go to town on the foam! It makes a mess but it gets into every nook and cranny. If you hold it close enough to the foam it will cut down 10-12 inches. I removed about 5 cubic feet of foam in 10 minutes, way faster than any other method I've seen so far.
Just thought I would share this because I have got so much good info from this site and wanted to contribute my share.
