About a week ago I got my first boat. It is a 14' Crestliner that came with a 6 hp Johnson outboard. Well, I think I might have tore up the motor all ready.
When I went to buy the boat, the guy started the motor in a trash can of water and it sounded like it was running pretty well. A couple days later my son and I took it out for the first time. I didn't know there was a difference between weedeater gas and outboard gas so I filled it up with gas and the same oil I used for my weedeater at a 50:1. Apparently the motor didn't like it because it ran like crap. It would start easily and as long as it was revved up a little it wouldn't die. It would run great in neutral, but as soon as I would put it in gear it would immediately bog way down. I figured it was just where It had been sitting and needed to be run for a while to clean everything out. Every once in a while it would take off like it should but then bog right back down. After about an hour we called it quits and decided to go back home. When we got to the dock another boater was there and advised me to use Seafoam on the motor. I put some Seafoam in the fuel tank, ran it for a little while in a trash can of water and all seamed well. My daughter and I took it out this time and we got about a half mile from the dock and the motor died. it would restart but then just die again so I paddled us back to the dock. I found out about marine 2 cycle oil when I got home. I put fresh gas and marine 2 cycle oil in it but I'm getting the same thing still, hard start then it will run for a few seconds then day. It makes no difference weather I pump the primer bulb or not.
Any Ideas on how bad I messed it up running the wrong oil or other things I should check before I tear into it and attempt a complete rebuild?
BTW it is a 69 Johnson 6hp model number 6R69M.
