.Mike
I just put together the cheapest possible high-quality shallow water pole anchor that I could, and thought I would share in case anyone else is looking to make their own.
I couldn't find any fiberglass poles locally, so I ordered from amleo.com. I used item FS3408 for $10.49 plus $5.99 shipping. I actually bought three, which worked out to $30.46 for 3, delivered. They were backordered for months, but I finally got them!
I couldn't find any cheap t-handles, even looking online. Shipping usually killed it. I ended up buying a 3ft paddle from Walmart for under $5, and cannibalized the handle: https://www.walmart.com/ip/Propel-By-Shoreline-Marine-3-Aluminum-Paddle/50279691
I used a $4.99 tube of Marine Epoxy from Home Depot, and a 1.5" #10 stainless steel screw ($1.18 for 3 @ HD). I already had both of those, or I would have chosen a better screw.
Pole $10.49
Shipping $5.99
Paddle $4.97
Epoxy $4.99
Screw $1.18
Total: $27.62
Building it is easy. Remove the handle from the paddle by drilling out the single rivet that holds it to the shaft. Drill so the rivet hole goes all the way through the handle, so it can hold the screw. Drill a hole in the fiberglass pole to accommodate the screw (outdoors with respirator and safety glasses).
Mix up some epoxy (wear gloves). Coat the screw hole, and put the screw through the handle and pole to affix the handle. Suspend the whole thing upside-down, and fill the gap between the pole and the handle with epoxy. Let it cure.
Take a sander, a file, or whatever you have, and sharpen the other end to a point. I coated mine with epoxy.
That's all there is to it. $28 and an hour of time. Testing tomorrow, weather permitting.
Pole $10.49
Shipping $5.99
Paddle $4.97
Epoxy $4.99
Screw $1.18
Total: $27.62
