[url=https://www.tinboats.net/forum/viewtopic.php?p=332162#p332162 said:
Clint KY » 35 minutes ago[/url]"]If the boat was not originally set up for cable steering it will be quite a task. You would need a console which would have to riveted or welded in. Some 16' boats have the setup but I have never seen a 14' with it. You would need a motor which was adaptable to cable steering and remote shifting and the remote cabling and steering assembly. While these motors are available they will be much more expensive than a tiller steered motor.
You might be better off looking for an aluminum Bass boat in that size which will have the steering already installed. And depending on where you are located, boats of that nature are more numerous (and hence less expensive) than getting a Jon and modifying it.
I might ask: What are you trying to accomplish by having cable steering as opposed to tiller steering?
