Have a 1987 Grumman fisherman 14 and a 1988 Johnson 9.9, I’m redoing the transom this weekend and was planing on building a jack plate to help the little motor all it can. I put the motor on the boat for the first time and to my surprise the cavitation plate is dead even to the bottom of the hull. Now I will be looking for a 25hp motor at some point I’m sure, I don’t want to drill a bunch of holes in my new transom when swapping motors, so my question is being the cav plate is even with the bottom of the hull would I gain anything from the jack plate with setting the motor back 3-5”? I figure if I go ahead and build the jackplate to keep this 9.9 where it is just set back then if I find a 25hp I won’t have to drill into my transom again to bolt the engine on.
Long story short I’m trying to see if it would gain anything or be benifical to set the motor back with a jackplate?
