Johnson weep hole?
PartsMan
Enid, OK
What would be coming out of this weep hole?
Lower unit oil or fuel, water and exhaust crud.
Update.
I checked the lower unit. It is full and clean.
Leaning towards the fuel water and crud mix.
Yeah that's normal. Unburnt fuel/oil from the exhaust.
whoopbass is right. That little weep hole is doing what it is suppose to do. If it were clogged it would eventually build up with will a goo and block exhaust gases and cause poor running.
A crud and goo removal system.
You think that's what the engineers called it? :mrgreen:
