Hay HD - If you are going to rivet thru hull below waterline, I recommend putting some marine sealant (Like 3M 4200 or 5200) on the tip of the rivet (push it out to get it in between collar & mandrel). A dab around the drilled hole is a good idea too.
If you are careful, you won't gum up your rivet gun!
