I have used glow sticks, LED lights and they cant compare to the reflector tape. Lasts forever and you can see it from a half mile away.
For jugs fishing when the lake is calm get a 2 ft section of half inch pvc, slide a5 inch piece of rebar inside then cap both ends of the pvc.
should look like a baton. Screw in an eyebolt (screw) into one of the end caps for your line. Cut about a foot off a swim noodle and shove the pvc end without the eyelet all the way into the noodle until it is flush. Should look like a noodle with a handle. Add you hooks (5 or less) and At least 8 oz of weight to the rig And wrap reflective (white on top of red) tape around the top of the noodle. when you deploy your hooks and toss this thing in the water it will stand out of the water about 10 inches. Grab the noodle lay it on its side and the rebar will slide to the side with the noodle and the jug will lay flat for hours untill you get a strike. When a fish pulls the line the side with the exposed pvc will tilt down, the rebar will slide to the bottom and the jug will stand up. Hit it with a light from a hundred yards if you see whiten xt to red move on if you see white on top of red, Fish on!
