LED Strip
https://www.amazon.com/gp/product/B00AJJDLHQ/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
I cut a roll of Scotch exterior double stick tape in half so it would be as wide as the led strip to attach to the gunnel of the boat, but under my decks I used NM wiring staples to go into the wood framing. I tried using a staple gun which ended up poorly. I was able to salvage some of the LED strip, but ended up having to order another.
https://www.homedepot.com/catalog/productImages/1000/ab/ab580d5d-1747-4ed0-bda3-5deebff6cc08_1000.jpg
https://www.homedepot.com/catalog/productImages/1000/7f/7fb36a3e-cbed-47d1-90b4-acfd420c18ea_1000.jpg
I didnt take any pictures, but the control box that comes with the LED strip is not waterproof or water resistant. I ruined the first one by leaving it out and morning dew shorted it out. After I ordered another set of lights I did some digging trying to find a potting material for the control module, but everything I saw was around $40 a tube, so after more digging, I didnt find a conclusive answer as to why 5 minute epoxy could not be used. The best reason I could come up with is that it wont allow the wires to flex and could result in breakage. After I pulled the back off the control box, I bought the loctite tube with the mixer tip and put a pretty good bed down. I covered the components on the board with a bead of epoxy to eliminate air pockets and pressed it down into the bed I had just laid. I then used the remaining epoxy to cover the board.
Ill see if I can't go out and film a quick video of the setup during the day.
