Looking for an upgrade
HahnZooKeeper
Fort Wayne, IN
Hello All,
We have recently finished a build and with all of the mods, the boat has gained a little weight. The 9.8hp Mercury still does OK, but I would like to get an 18hp or 20hp for next season. I am pretty sure I need a long shaft and would like to stick with an older Mercury (familiarity). Not Having alot of expendable cash righ now, just getting started looking. I would like to use the 9.8hp as a trade +$, but don't really know what it's worth either. I would love to go with a four stroke, but I think they're out of my $ league. HELP PLEASE!
Check the height of your transom - that will tell you long shaft or short shaft. Long shaft is 20" and the short shaft is 15" to keel (I may be wrong, but I think that's the right numbers.)
But as far as motors, keep an eye on craigslist. You should be able to find some pretty good motors out there. I've got a 70 and a 73 Johnson 20hp and they work great.
what size boat do you have(total weight with gear n people) and what year is your merc?
Shawnfish,
The boat is a 14' Starcraft rated for a 25hp motor. We removed the middle seat, installed the 3/4" thick flat floor on a wood frame, casting deck, battery/electrical compartment, and a foot control Minn Kota trolling motor at the bow. I'm really not sure of the weight of the boat with or without people. I estimate that we added about 150-180lbs. with all the mods.
The outboard is a 1974 Mercury 9.8hp. Rebuilt the carb last year along with new plugs. It runs great, but is a little short on power with the additional weight. I think you can click the hyperlink at the bottom of this post to see our pics.
HahnZooKeeper said:
Shawnfish,
have you checked your RPM's? added weight will make your prop(motor)work harder and reduce RPM's and power. maybe try a prop with less pitch. if i was you i would go with the biggest motor you could buy that being a 25hp.
Don't pass up a good 30 hp motor if it comes up.
Shawnfish,
Thanks I have thought about that, but I am not sure of how to check the RPMs. I would need to check with the boat in the water, correct? I am not sure what tools I would need for this either.
