onthewater102
Apologies, I've had a few of these and I've been lucky enough to have the variants which didn't have thermostats, but I see now in block configuration #2 under my s/n there is a model variant that has a t-stat.
Bign0703 said:Ok guys. I'm in a pickle with this thing. Replaced the entire impeller assembly along with the water tube seals and she won't pump a drop. I've heard several say these motors have to be submerged to pump and won't pump off a hose but don't know for myself. I plan to dip the lower into a tank and running it with a drill to see if it is pumping but anyone have any idea what could cause this. When it's on a hose it acts as if all the water is flooding the mid section but not going through motor.
Pappy said:By the way, when you are running in a barrel or bucket the water level has to be a few inches above the parting line where the gearcase meets the exhaust housing. That will insure your water pump is fully submerged and capable of pumping.
