Seth
My boat is 18' 3" long and has 8awg wiring from front to back of the boat. A 40 amp breaker is installed by the battery positive. The troller is a 55# 12v Minnkota Edge and it is supposed to draw 50amps on the highest speed. When I run the troller on speeds 4 and 5, it will trip the breaker. It happens fast on speed 5 and takes a little longer on speed 4. After it starts tripping, the breaker gets pretty warm and it will start tripping easier. Will I be ok going to a 50 amp breaker? Minnkota's "recommended" self brand breaker is rated at 60amps, but it also costs $40.
My friend had the same type of boat with the same wiring and always ran a 24v 70# MK Edge without ever tripping the breakers. On Minnkota's site, it says that the 24v 70# only drew 42 amps instead of the 50 like mine does.
