missing something on the bow, ??
dkonrai
walnut creek, california
ok am i missing something here? or it just me. there was some evidence of some wood however i am not sure how to tie in the bow. planning on using some 1x material, standard wood (douglas fur). the question is how do i tie in at the bow? just slot the wood and beat it in? do i need to taper the wood? can i use something other than wood? as the wood will sit on the trailer's roller.
thanks
dino
i ended up using a hockey stick extension. ran it through a table saw, filled the void with builders epoxy, as well as the shaft. then i placed it in the slot, a couple of clamps and waited till it dried.
a little belt sanding and voila! problem solved. i painted it with two coats of deck paint. hope this works.
dino
