Fishon72
After thinking I had the motor running flawlessly, I ran into another issue while out on the water the other day. After the motor started up the first pull I began to head out and while throttling up the motor it slowly began dying and stopped. I got it started easily enough but it didn’t run for long before dying again. Good thing I brought the oars
I can start it up as long as the choke is all the way out, and it idles with the choke all the way out; once I push the choke in and try to throttle up the motor slowly begins to die. I assumed this was likely due to a dirty carburetor, so I ordered a rebuild kit and took my carb out this afternoon; to my surprise it looked squeaky clean with no sign of fouling. The kit should be here tomorrow so I’ll switch everything out anyway but I can’t imagine that’s the issue. I was running the fuel/oil mixture a little rich (accidentally dumped about 8 extra ounces of oil into 6 gallons fuel) but after reading some opinions online it didn’t seem like this would cause an issue, and it ran about 4 gallons of this mix just fine.
Thanks in advance!
Thanks in advance!
