Find the pee hole and follow the hose up to the block. Carefully remove the hose from the fitting, and start the motor on the hose. If she pees strong from the fitting, it's the hose. If it only dribbles, use a small piece of wire or similar to poke in there, and usually a chunk of something will come out.
In extreme cases, you may have to remove it, but be careful, as sometimes they are corroded and will break off before coming loose. Then you have to drill and tap the hole, which is a pain.
Around here, the most common culprits are little, tiny mud wasps they call "Dirt Dobbers" that will fill up a pee tube surprisingly fast and surprisingly deep. Sometimes, they will have 6" of nests inside a tube.
Many people stick a golf tee or any kind of little stick in their pee holes to prevent this. The nice thing about a piece of twig is that when you start the motor, the water blows the twig out, and you don't have to chase it down.
