Motor size question and help identify my boat
Olsmokey
Hello new to the site. I have a sears v hull 12' not sure where the with length is taken. Transom is about 42". Looking at a gamefisher 9.9. Is that too much motor for my boat? Im sure ill be upgrading to something a little bigger in the next 2 years like a 14' jon. Im sure it would be fine for that application. Also any feedback on game fishers? This is my first boat. Ive gone from kayaks to a canoe with an electric motor to this. Just me and the wife fishing colorado lakes. Thanks in advance for your help. Shawn
Hi there,
I have a 14' V-hull that is titled as a Sears also...however it was manufactured by Richline.
From what I understand, Sears never made any boats...they branded boats built by certain manufacturers. Do you have any sort of Hull ID plate? If not, a picture of the boat may help someone on here identify it.
Once you know who manufactured the boat, you can research the specs for it - including HP rating.
Hope this helps.
Walter
I had an old 12' Sears v-hull a few years ago. I never put an outboard on it, but stability-wise I always felt it was better than the 1436 flat bottoms I have been in. And plenty of them run 9.9 hp motors without problems.
A few pictures. My hin comes back as colorado home made boat. Sears manufacturer year 1900.
    46.7 KB
    47.9 KB
    62 KB
    39.6 KB
    67.1 KB
    64.2 KB
I have the exact same boat-a1976 model mine is. The rating plate on it says 9.9 max if that helps you
I picked up a nissan 4 stroke 6 hp. It runs great but im a little disappointed on the top end
Sent from my SM-S975L using Tapatalk
