lgpjr49 said:Yeah it's fairly simple. I got my hatch kit and I cut out the template that came with it. Next I cut out the foam that was in the bench underneath. I only pulled out the amount of foam that I needed to store my biggest item (portable stern nav light) and once that was all out I vacuumed it all out then just attached the hatch to the bench very simple. My only problem now is, the bench flexes a lot when you sit in the pedestal seat and I need to find a way to stiffen it up without ripping out more foam
Had this problem in the rear bench seat when someone would sit on the pedestal. I made a small frame out of aluminum angle that fits under the seat base. It was a very minimal amount of foam taken out. The frame just basically made an "H" under the base to displace the weight across more of the seat to keep from flexing.
