Big ol rod locker and recessed foot control are some must haves. Next is the locker for my tackle. The rod locker can hold plenty of poles at any length.
Everything is just roughed in and still needs finish work. As you can see the opening allows for the rods to be push all the into the bow area underneath the deck. Also I can still use the original storage.
Looking good so far...... The pics maybe loading upside down due to the size of them. Not sure what the official size of pics allowed here is, but I can remember putting up pics of my boat and just kept shrinking them down to get them to show correctly.
How much foam did you have packed in your bench? Any plywood under the aluminum? Curious how much is really in there bc I've thought about putting the battery there too.
There is two layers of foam. 2/3 of it is the cheap popcorn foam. The bottom layer is the higher buck closed foam. It is filled bottom to top minus a layer of 3/4 marine plywood that supports the bench. I gained a lot of storage doing this. Well worth it. I am reinstalling the plywood beneath where my seat is going and on the other side of my hatch for support. I'm going to be laying a aluminum floor in it also. It's going to have to be installed in three sections.
Here is the beginning of the "tackle box". The boxes will be able to be removed completely with a few bolts. That will make it easy to store the tackle inside during the winter and also have easy access for running electrical.
The tackle box is sitting on four pieces of aluminum that will have a total of fours bolts that will hold it in place. Each bolt will have a welded nut on the bottom side of the plate. That way all you need to do is take a driver and remove four bolts and out she comes! It's nice to be able to use that area for camping gear when we are out on the sand bars of the Mississippi.
Here is the tackle box locker with lid and latch the installed. Found the latches on Amazon for $28 a piece. Pretty sweet deal considering they lock and are of pretty good quality.
All the pieces are in place and secured finally. There are still some trim and filler pieces to add. Can't wait to start running wire and getting everything mounted.
Here are some pics of everything layed out on the boat before I started installing. I wanted to get a good look at it before I started to make sure it all worked where I wanted it.
