I recently put a bigger motor in my jet went from a 650 to a 760 Yamaha. I had a issue with the boat shifting edges before when I had the 650 and ran empty but now it does it worse and even with light load its like the v is on the edge of being either in the water or out so maintaining control can get hard at high speeds the water will catch one side or the other and it with push the nose one way or the other so I constantly stear back and forth. Also my stearing is pretty loose I have to turn pretty far to get movement so the whole motion is exaggerated.
Im looking to change the stearing the type I have has a threaded conection with a ball quick disconnect. on either end. Teleflex is what everyone uses but the connections are different I'm hesitant to buy it because I don't know if it will work has anyone done been there done that?
Also more important is any solution to my mv problem to stop it from swaying other than just running loaded down all the time. My buddy mentioned like a skeg or keel. like maybe putting a piece of angle aluminum off center maybe a couple feet long toward the back?
