JoshKeller
hey guys, new here. Ive been reading for a while to get some ideas for my new project. Well here goes!
picked up this 2001 14' x 36" jon boat and trailer for $400 locally. added my 9.9, decking, two trolling motors, and picked up a set of clamp on navigation lights. Adding a humminbird mounting bracket, power cable, and side imaging transducer so I can swap one of my 797s from bass boat to jon boat. I bolted on a piece of angle iron to the front seat for the decking to sit on. Because I wanted the deck to be removeable, I welded two 5/16" nuts onto the bottom of the angle so I can put two bolts through the deck and lock it down. Next up is locating a 20 - 25 hp jet motor. All plywood was 19/32" coated with fiberglass resin to seal out moisture (i had a 4 gallons left over from when I redid my bass boat stringers), and the carpet is indoor/outdoor 6 x 8 for $19 at lowes.
as I got it.
fitting the deck
adding the compartment.
the two bolt mounting system, trolling motor bracket made of 2 x 6's, and trolling motor plug.
getting everything fitted and installed after carpeting.
the finished project.
com/data/500/medium/IMAG02321
as I got it.
fitting the deck
