brholth8
Right now I'm waiting until I can afford carpet before i can get further.
richg99 said:I've never seen a drain hole that large. Almost looks like it had a sleeve of some kind that got lost. I'll bet you can find a way to sleeve it. You will probably have to epoxy the sleeve in so it will fit a standard plug. Looks like you are having fun with the re-build. regards, Rich
Go with this.richg99 said:I wouldn't make any additional holes. Use the epoxy filled area to re-drill for the correct size. Let's see it when it is finished. Rich
Oldgeek said:On Iboats they sell a brass plug kit. It has a fitting that fits on the outside with bolts or screws and then a brass plug screws in. My drain has been distorted and I may have to go to that if my plug leaks more than I'm comfortable with. I agree with going to Walmart and seeing if they have a larger plug first. Good luck!
