Catch Release Repeat
sonny.barile said:If you want to stiffen up the conduit fill it with expanding foam.
Not a bad idea, couldn't hurt
Tman said:if you cant find the correct angles for those pipes you can always use regular white PVC pipe heat it and bend it to whatever shape you'd wish. i did it with my frame for my cover. a harbor freight heat gun is all i used.
https://forum.tinboats.net/viewtopic.php?f=21&t=42520
side note. i'm south of you off 219 near bradford pa. are you going out on lake Erie or are there smaller lakes your fishing in?
RiverBottomOutdoors said:Is that a rod holder? Like a trolling rack?
Catch Release Repeat said:Still tossing around the idea of hydro turf. I want it but don't want to pay for it. (Common problem)
Johnny said:I like the trolling motor you found - I have not seen that design before.
